18 years agohow to config fpga with flash?
hi , i am Tig , a starter . and my board is Nios II Embedded Evaluation Kit, Cyclone III Edition. the flash device is cfi_16M. i want to know how to use flash config the fpga i h...
18 years agoOK, that isn't conflicting with flash configuration anyhow. But you have the restriction that you can't capture signals directly at double data rate pins (DDIO registers) respectively with double data rate general. So you can't see the particular DDR timing, but you can see of course the sequences of control signals and addresses, and indirectly the RAM read and write data at the demultiplexed "slow" side of DDIO.
