18 years agoHow to: compile to single file
Hi, I have a hierarchically project with several VHDL files. Is it possible to make 1 single file, that contains everything (Portmaps, entity, architechures, processes etc.)? Hopefully a VHDL file...
18 years agoHello,
create hdl file for current file is the basic operation to convert graphical (*.bdf) top levels to VHDL or Verilog. Depending on your design there may be additional manual steps necessary. 1. In a bdf-file, non-VHDL compatible port naming could have be used, e. g. pin1-3. It must be changed to VHDL conform names (case insensitive alphanum_underline without leading digits). 2. If Megawizard lpm functions have been used in graphics, for the AHDL megafunction wrapper a equivalent VHDL version must be generated by Megawizard or, what I prefer, replaced by a direct instantiation of the Megafunction VHDL library. Finally, all VHDL sources must be merged manually, if a single file is needed. Regards, Frank
