How to choose device : CPLD or FPGA ?
I want to implement a polynomial function to continuously process a digital temperature signal and output a variable based on such evaluation. What device to look out for ? CPLD or FPGA ?
How can I decide that this implementation would need this much LEs ? Please help in this regard.13 Replies
Well , I think of going ahead with MAX V CPLD having 570 LEs.
Board cost is also very cheap. - Altera_Forum
Yes, I meant that.
--- Quote Start --- I intend to use a fast ( bare ) thermocouple whose response time is 0.3 sec, such that the entire calculation wouldn't cross 0.5 seconds in giving output. --- Quote End --- At speed you also have other options than a CPLD or FPGA ... - Altera_Forum
--- Quote Start --- Pipe-line the multiplication. You can multiply + accumulate. A MAX II device should do it. --- Quote End --- You mean 'serialise it'. Pipe-lining increases speed but doesn't decrease the amount of LUTs. A 32 by 8 serial multiply takes about 190 Logic Cells in MaxII. This is some 'old' AHDL code I did many years ago, I guess it can be improved upon though. paawansharmas didn't indicate how fast he needs to run. - Altera_Forum
It can be done with 38 adders or in total about 1000 'full adders', which comes down to about 1000 LE's for a MAXII device (assuming a few AND-ing functions can be combined at the same time), requiring a EPM1270 device, so you're better off using the smallest of Cyclone II, III or IV series and just use the hardware multipliers.
it wont be as simple as 43 adders
if x is 8 bits, x^2 will need 16 bits, and x^3 needs 24. Then if A,B,C,D are 8 bits again, the output is going to be 32 bits. So thats a lot of adders. Different devices have different size LEs - some have 4input LUTs, some have 6. So to estimate the number of LEs required its simpler just to write the code and compile it. - Altera_Forum
Considering
Y = Ax3 + bx2 + Cx + D I conclude at 5 multipliers and 3 adders ( using both mul. and add.) or 43 addres ( using only adders, for a 8 bit input) It can give a rough estimate of LEs consumed ? - Altera_Forum
Thanks Tricky for your valuable suggestions.
