12 years agoHow to check which FPGA is assembled on the pcb?
Hi all, I am using pcb designed for many various projects. On this pcb can be placed one of the following FPGA devices: 5CEBA4 or 5CEBA5 or 5CEBA7 or 5CEBA9. The device which will be a...
12 years ago --- Quote Start --- If you have JTAG connected to your processor, then that would be easiest. Its pretty easy to read the IDCODE or USERCODE via JTAG - you just bit-bang the JTAG TAP machine into the appropriate state and read out the data. --- Quote End --- But the IDCODE is not unique for each part. I don't know about the Cyclone V's mentioned, but when you use jtagconfig you see a list of candidates for the given ID: 02A030DD 5AGT(FD3H3|MD3G3)/5AGXBB3D4/.. 029030DD 5SGXEA7H(1|2|2ES|3|3ES)/..
