8 years agoHow to check whether a Cyclone IC is defect
Dear Members! I am working since 5 years with Cyclone II EP2C8 simple boards, I am developing some hobby projects at home. Yesterday some strange thing happened to me, as I improved my VHDL...
8 years ago --- Quote Start --- I don't know, and assume you already did, but what happens when you rollback your changes? --- Quote End --- I did not do a rollback. But the question was rather how to test a Cyclone device. The backgrund story was only example what can be occure in that situation. Every electronic device has a lifetime span, maybe it gets a damage during the normal working situation, and sometimes it is necessery to make a "selftest" somehow, to avoid loosing developement time due to defect gates. I could write a code with more thousand or million of XOR gates to check whether the coming out result is expected, but don't belive there is no already working solution for that problem.
