How to check the usage of GCLK resources in quartus project?
I asked "Is it possible to see how many BUFG by using Quartus software?" in https://community.intel.com/t5/Programmable-Devices/About-the-BUFG-specification-in-Intel-FPGA/m-p/1438749 , and got the answer: Quartus compilation report tells which resources are utilized for specific signals. Generally, it's rarely necessary or even useful to assign clock resources, e.g. clock control blocks in a design manually.
Thanks for that, however, I am still not clearly about it, is there a demo design that assigned clock resources, e.g. clock control blocks manually? I need to check if the Quartus compilation report tells the usage of GCLK resources. Or the compilation report can't tells it?
- SyafieqS
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
- SyafieqS
May I know if there is any update from previous reply? Did you manage to see the report?
- SyafieqS
There should be a report in compilation report for global clock resource usage. You may check it.
- sstrell
There is a Global Signals report in the Compilation Report which is probably what you are looking for. I forget where it is (don't have Quartus open presently), but it's there.
