how to bypass IO limit to get a utilization summary?
Yes, a quick and dirty way is to create a new module which takes all, or just some, of your I/Os as inputs/outputs (for example, of some combinatorial operation), to reduce the number of ports which need to be mapped to available pins by the fitter. At the end, just look at the resource utilisation and subtract whatever is used by the "helper" module. Be aware however, that the real resource count depends also on routing and placement and you will not be able to get a perfectly accurate resource count using this method. The correct way is to use design partitions with virtual pins, to achieve the closest resemblance to the final fit/place of your logic without having the whole design in place - but this is too much to explain in a forum post. Quartus Handbook has all the details on how to do it if you are interested.
