9 years agoHow to build linux for DE2-115
I built buildroot and u-boot from alteras repository on github. Now I want to build linux but there is no config file for ep4ce115 linux config. How can I continue?
$ ls
buildroot linux-socfpg...
9 years ago --- Quote Start --- As far as I know, unfortunately there is no config file for DE2-115. You may want to try 3c120, but I am not sure if that will work --- Quote End --- It seems that the config file for 3c120 actually works. It also outputs from my jtag that is says 3c120 so it seems compatible My Altera DE2-115 outputs the following
$ jtagconfig1) USB-Blaster
020F70DD EP3C120/EP4CE115
