9 years agoHow to build linux for DE2-115
I built buildroot and u-boot from alteras repository on github. Now I want to build linux but there is no config file for ep4ce115 linux config. How can I continue?
$ ls
buildroot linux-socfpg...
9 years ago$ quartus_pgm -m jtag -c USB-Blaster[2-2] -o "p;tPad_Selector.sof"
Info: ******************************************************************* Info: Running Quartus Prime Programmer Info: Version 16.1.0 Build 196 10/24/2016 SJ Lite Edition Info: Copyright (C) 2016 Intel Corporation. All rights reserved. Info: Your use of Intel Corporation's design tools, logic functions Info: and other software and tools, and its AMPP partner logic Info: functions, and any output files from any of the foregoing Info: (including device programming or simulation files), and any Info: associated documentation or information are expressly subject Info: to the terms and conditions of the Intel Program License Info: Subscription Agreement, the Intel Quartus Prime License Agreement, Info: the Intel MegaCore Function License Agreement, or other Info: applicable license agreement, including, without limitation, Info: that your use is for the sole purpose of programming logic Info: devices manufactured by Intel and sold by Intel or its Info: authorized distributors. Please refer to the applicable Info: agreement for further details. Info: Processing started: Mon Mar 13 17:10:04 2017 Info: Command: quartus_pgm -m jtag -c USB-Blaster[2-2] -o p;tPad_Selector.sof Info (213045): Using programming cable "USB-Blaster [2-2]" Inconsistency detected by ld.so: dl-close.c: 811: _dl_close: Assertion `map->l_init_called' failed! Info (213011): Using programming file tPad_Selector.sof with checksum 0x00BBDF04 for device EP4CE115F29@1 Info (209060): Started Programmer operation at Mon Mar 13 17:10:05 2017 Info (209016): Configuring device index 1 Info (209017): Device 1 contains JTAG ID code 0x020F70DD Info (209007): Configuration succeeded -- 1 device(s) configured Info (209011): Successfully performed operation(s) Info (209061): Ended Programmer operation at Mon Mar 13 17:10:11 2017 Info: Quartus Prime Programmer was successful. 0 errors, 0 warnings Info: Peak virtual memory: 453 megabytes Info: Processing ended: Mon Mar 13 17:10:11 2017 Info: Elapsed time: 00:00:07 Info: Total CPU time (on all processors): 00:00:01 ------ bams colleges bangalore (http://www.admissiongroup.com/bams-colleges-course-direct-management-nri-quota-admission-educational-consultants-fee-structure.html) sri krishna institute of technology bangalore admission (http://www.admissionpro.in/sri-krishna-institute-of-technology-bangalore-fee-structure-nri-direct-management-quota.html)
