dpenev
7 years agoHow to bring up FPGA board with short in the power rails.
Hello, I am trying to bring up few new prototypes using Stratix IV FPGA (EP4SGX70HF35C3N ) One of board is working fine. I have trouble switch the other one. Almost all power rails going to the FP...
AnandRaj_S_Intel
7 years agoHi,
Debug steps
Check board for Solder Bridging (Specially near all power, ground pins).
Method -1
Force current and measure voltage(FCMV) which will help in finding the short.(source-measurement unit /Parametric-measurement unit/multimeter with high Resolution.
Method-2
You apply power, and look for a temperature rise on a specific component. It works quite well.
Method-3
Removing components.
- List down the components on power rails(Regulators and passive components) try to suspect the component.(In my view i will suspect the 2.5V, 1.8V, 0.9V and 1.5V start heating DC-DC regulators->passive components ->FPGA)
- If possible can we desolder the regulator and check.If short persist,
- Try to do same for passive components on regulators and FPGA side.
Anand Raj Shankar
