17 years agohow to bootload from a compact flash card
I'm working on the Altera's EP2S60 Development Kit, which has the Stratix II FPGA on board. Now I am planning to save my design firmware on a compact flash (CF) card, so that the FPGA can bootload di...
17 years agoThanks!
I think that it is a suitable scheme to use a configuration controller (MAX II or microprocessor) and a CF card for the non-volatile configuration. In FPP mode, it should work. However, my current development board S60 connect the controller with a flash memory together. In this case, I might need change the configuration of the controller to apply for mine.
