12 years agoHow to boot baremetal code from sd card
Hi I want to boot the baremetal code from sd card. I need some examples and the procedure about how to write the binary to SD card
12 years agoHello,
booting own baremetal code from SD Card or other Flash device is quite simple. All you need is a preloader, which is started first on bootup. the preloader initializes the basic functions of your HPS and loads i.e. code from FLASH or SD-Card into the SDRAM. The code that is loaded can be either an U-Boot, that loads your Linux image or it could be directly an baremetal application. A tutorial for the preloader can be found here: http://www.rocketboards.org/foswiki/documentation/gsrdpreloader#generating_the_preloader if you want to store your baremetal application on a FAT partition, you have to enable some settings for the preloader: http://www.rocketboards.org/foswiki/documentation/preloaderubootcustomization#preloaderubootfatpartition The image for the baremetal application, stored on the SD-CARD have to be created with a command like this:mkimage -A arm -O u-boot -T standalone -C none -a 0x01000000 -e 0x01000000 -n "Name_Of_Your_Application" -d baremetal.bin baremetal.img
The mkimage tool can be found in the source folder of the generated preloader. That's all. If you've any more questions, just ask.
