18 years agohow to avoid this warning?
Recently,i am working with EPM570T10I,program with Verilog hdl. When i compiler the code,but there is a warning in Quartus II: Warning: Found 1 node(s) in clock paths which may be acting as...
18 years ago --- Quote Start --- In your code you have tyhe following stuctures assign flg_oc_2 = flg_oc_1; always @ (posedge out_feed or posedge flg_oc_2) begin if (out_feed) begin flg_block_drive_1 <= 1'b0; end else if (flg_oc_2) begin flg_block_drive_1 <= 1'b1; end end You may be assuming that flg_oc_2 is just a strobe but in fact the coding style infers a clock! The above code will infer a FlipFlop for flg_block_drive_1 with flg_oc_2 as a clock input. So the warning is correct. Hope this helps --- Quote End --- After looking into the RTL view of the Quartus project I found, that the output of the register is driving the clock input of another FF. Quartus has to treat this signal as a clock. The warning is correct.
