18 years agohow to avoid this warning?
Recently,i am working with EPM570T10I,program with Verilog hdl. When i compiler the code,but there is a warning in Quartus II: Warning: Found 1 node(s) in clock paths which may be acting as...
18 years ago --- Quote Start --- hi,i do not define any setting excepting for the setting "not a clock". The code: module over_current_check ( clk_1m, over_current_signal, rst_n, flg_block_drv, flg_over_current ); parameter CNT_FORTY = 6'b101_000, CNT_TWO_THOUSAND = 15'b100_111_000_100_000; input wire clk_1m; input wire over_current_signal; input wire rst_n; output wire flg_block_drv; //over current,disable drive output 20ms output wire flg_over_current; wire flg_oc_2; reg flg_oc_1; //if the over_current_signal keep low for 40us,flg_oc_1 keep high level 1us reg out_feed; reg flg_block_drive_1; //if flg_oc_1 is high,flg_block_drive_1 keep high for 20ms reg [5:0] cnt_40; reg [14:0] cnt_20000; always @ (posedge clk_1m) begin if (!rst_n) begin cnt_40 <= 6'b000000; flg_oc_1 <= 1'b0; end else begin if (!over_current_signal) begin if (cnt_40 == CNT_FORTY) begin cnt_40 <= 6'b000000; flg_oc_1 <= 1'b1; end else begin cnt_40 <= cnt_40 + 6'b000001; flg_oc_1 <= 1'b0; end end else begin cnt_40 <= 6'b000000; flg_oc_1 <= 1'b0; end end end assign flg_oc_2 = flg_oc_1; always @ (posedge out_feed or posedge flg_oc_2) begin if (out_feed) begin flg_block_drive_1 <= 1'b0; end else if (flg_oc_2) begin flg_block_drive_1 <= 1'b1; end end always @ (posedge clk_1m) begin if (!flg_block_drive_1) begin cnt_20000 <= 15'b000_000_000_000_000; out_feed <= 1'b0; end else if (flg_block_drive_1) begin if (cnt_20000 == CNT_TWO_THOUSAND) begin out_feed <= 1'b1; cnt_20000 <= 15'b000000000000000; end else begin cnt_20000 <= cnt_20000 + 15'b000000000000001; end end end assign flg_block_drv = flg_block_drive_1; assign flg_over_current = flg_oc_1; endmodule --- Quote End --- Hi, you are right , the "not a clock" is only valid for I/O's. It is not valid for internal nodes, therefore the additional warning.
