18 years agohow to avoid this warning?
Recently,i am working with EPM570T10I,program with Verilog hdl. When i compiler the code,but there is a warning in Quartus II: Warning: Found 1 node(s) in clock paths which may be acting as...
18 years ago --- Quote Start --- THX for your help first.The method you mentioned above i have tried,but the warning is still,and another warning happens: Warning: Found invalid timing assignments -- see Ignored Timing Assignments report for details。 No timing path applicable to specified destination。 By the way,the signal “flg_oc_1” is a internal variable,not a IO。 --- Quote End --- hi, it looks like that you have a clock setting defined for this signal (?), but you defined now that it is not clock. The constraint is no longer applicable.
