SOdin1
6 years agoHow to access Stratix 10 AS configuration pins in user mode?
Is there a way to access Stratix 10 AS configuration pins (SDM_IO*) in user mode, e.g. after device configuration via JTAG? The goal is to program SPI flash with custom image through FPGA bypassing ...
YuanLi_S_Intel
6 years agoSorry sir, all stratix 10 involves with SDM. When you talk about configuration pin, which pin are you refering to?
You may refer to our pin connection guidelines to see if any of the pin can be used as I/O pin during user mode.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/stratix-10/pcg-01020.pdf (Page 7)
If it can be used as normal I/O pin during user mode, you may freely connect your design to these pin.
