SOdin1
6 years agoHow to access Stratix 10 AS configuration pins in user mode?
Is there a way to access Stratix 10 AS configuration pins (SDM_IO*) in user mode, e.g. after device configuration via JTAG? The goal is to program SPI flash with custom image through FPGA bypassing ...
YuanLi_S_Intel
6 years agoHi Sergei,
May i know are you using the configuration pin to do configuration right? if it so, then you will need to use this IP.
In Stratix 10, all the configuration will need to go through SDM in order to perform it Thus, sending command to SDM using this IP is definitely correct.
