How the "PARAMETER"/"localparam" in verilog mapped to hardware?
Parameters have to resolve to a fixed value at compile time, so the design is simply synthesized based on the parameter value used. If you're using a parameter, for example, to specify a bus width and you set the parameter to 8, enough resources will be used to implement an 8-bit wide bus.
#iwork4intel
- HBhat27 years ago
Contributor
@sstrell ,
For example, I have a header pattern to send (localparam header = 0xA5A5), I will store this as local parameter and I will assign my databus for defined interval. (data_o <= header ;). As, data_o inferred into multiple D-flip flops, my specific question is how does the header will be inferred? Whether this localparam will be stored in block RAM or by means of any other primitives ?
With Regards,
HPB
- sstrell7 years ago
For your example, it would probably be synthesized as just pull-ups and pulldowns since it's a constant value.
#iwork4intel
