How much negative current can a FPGA Cyclone II user pins I/O can drive ? Sum of pin currents
hi, on https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyc2/cyc2_cii5v1.pdf
table 5-1 "Absolute maximum rating" : -25mA
On https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyc2/cyc2_cii51010.pdf
Programmable current strength : 24mA by default.
My end prupose is that my pins currently drive down to 0V {one resistor, one LED in serial to 3.3V} and wonder if FPGA Cylone II pins can drive -7 mA.
Are you referring to -25mA minimum on Iout on Table 5-1? If that is the one you are referring to you cannot set it below -25mA since it may cause permanent damage to your device.
Thank you.
- mmoussea5 years ago
Hello.
I may ask differently :
Can I drive -7mA per pin (current flow into an output pin), not exceeding -240mA per 8 or 12 pins (depends of banks) ?
Best regards.
- AminT_Intel5 years ago
Yes, absolutely!
