16 years agoHow much is the maximum current of FPGA
Hi,everyone, I'm working in a project using EP1C6Q240.The datasheet says that the Current Strength of each I/O pin can be set up to 24mA.Suppose I use 100 pins to output 20mA at the same time,the ...
16 years agoMake sure you do a thorough thermal analysis on this!
