MS
6 years agoHow many solder cycles does Arria10 support?
Hi, Sometimes it happens, that PCBs need to be reworked. Is there any specification about the supported number of soldering cycles an Arria10 FPGA supports? Where can I find that documented? Be...
NurAiman_M_Intel
6 years agoHi MS,
Thank you for contacting Intel Community.
To know the soldering information during assembly PCB, you may refer to AN 114 in the link below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an114.pdf
For process reflow, kindly refer to the link below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an353.pdf
Let me know if you need further information.
Aim
- MS6 years ago
Hi Aim,
Thanks for your answer. Having a look at the application notes you pointed to, I found the interesting and valuable. Yet, the point of the question unfortunately seems not hit.
Is there a limitation in the number of reflow-cycles an FPGA can run through before the warranty by Intel is impacted?
Best wishes,
MS
