MS's avatar
MS
6 years ago
How many solder cycles does Arria10 support?
Sometimes it happens, that PCBs need to be reworked.
  • Is there any specification about the supported number of soldering cycles an Arria10 FPGA supports?
  • Where can I find that documented?
Best wishes,
MS
  • Hi MS,
    I hope my previous response have addressed your question. Fell free to open new question if there is any. I will continue to close this case.
    Aim
  • Hi MS,
    Just would like to clarify if you are referring to the reflow peak temperature of Arria 10. If yes, you may refer to AN353 document, Table 2:
    https://www.altera.com/en_US/pdfs/literature/an/an353.pdf
    For Arria10 which is lead free part, the peak reflow temperature could be referred to Table 4 of AN353.
    Time within 5C of peak Tp of lead free part is 30 seconds while the number of reflow cycles = 3.
    The max reflow time for our device is 3 times. The 3 time reflow adopted by JEDEC/IPC 020-D is based on the assumption that most devices on the PCB will see 3 temperature excursion.
    · 1st reflow
    · 2nd reflow (double sided board)
    · 1 extraction (or rework)
    They expect the device to be still functioning with 3 times reflow.
    Hope this clarify.
    Aim
  • Hi MS,
    Thank you for your respond. Apologize that my previous respond did not answer to your queries.
    I will need to check this with our internal team. I shall get back to you next week with the findings.
    Thank you for understanding.
    Aim
    • MS's avatar
      MS
      Hi Aim,
      Thanks for your answer. Having a look at the application notes you pointed to, I found the interesting and valuable. Yet, the point of the question unfortunately seems not hit.
      Is there a limitation in the number of reflow-cycles an FPGA can run through before the warranty by Intel is impacted?
      Best wishes,
      MS
