Sajith_K_Intel
6 years agoHow is an ALM used as Memory cell inside MLAB?
When an ALM inside MLAB is configured as a 32x2 simple dual-port memory, ALM block at least need 5-bit read address, 5-bit write address, write enable, clock, and byte enable. But for an ALUT, only ...
KhaiChein_Y_Intel
6 years agoHi,
Can you check if the settings are the same?
Sajith_K_Intel
6 years agoDo we have any document showing internal architecture of "ALM when used as MLAB cell"?
