Sajith_K_Intel
6 years agoHow is an ALM used as Memory cell inside MLAB?
When an ALM inside MLAB is configured as a 32x2 simple dual-port memory, ALM block at least need 5-bit read address, 5-bit write address, write enable, clock, and byte enable. But for an ALUT, only ...
KhaiChein_Y_Intel
6 years agoHi,
I try to create a simple test case similar to the screenshot you have attach here but I could not replicate. Could you provide a simple test case for investigation?
KhaiY
Sajith_K_Intel
6 years agoNow I do not have a testcase, But you should be able to do it by using a ram template, and inferring MLAB memory.
