17 years agohow does quartus decide to remove logic?
I guess this is a bit of a newbie question (newbie to quartus not hardware design - I'm an old ASIC guy)... I've crawled through the manual (well, it's 1200 pages long, so I'm sure I missed the...
17 years agothis particular design has a CPU booting off its internal memory (which I am manually loading via code running during reset) which takes data almost directly from the top layer (which doesn't get synthesized away) and drives data back up to the top layer... There are floating nets that I grounded, so I'll start by taking a closer look at those. This particular IP vendor seems to like using IO buffers to implement multiple drivers of control pins (jeez), so there's probably an issue here also...
Thanks for all the ideas..
