how do timing constraint for I2c bus
- 3 years ago
Sorry for the late response. You may use set_max_delay instead of set_input_delay since the I2C is pretty slow. You may use below constraint, this is the typical values used.
set_max_delay -from [get_ports {eeprom_scl}] 50
set_min_delay -from [get_ports {eeprom_scl}] 0
set_max_delay -from [get_ports {eeprom_sda}] 50
set_min_delay -from [get_ports {eeprom_sda}] 0
Nurina
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to https://supporttickets.intel.com , view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 4/5 survey
Nurina
