lipingx
3 years agohow do timing constraint for I2c bus
In my design, I used system clk = 3.125MHz to realize I2c SCL,SDA 200K i2c bus.
I used counter in the verilog, so both SCL and SDA are treated as data line.
Then, how to do timing contraint?
- 3 years ago
Sorry for the late response. You may use set_max_delay instead of set_input_delay since the I2C is pretty slow. You may use below constraint, this is the typical values used.
set_max_delay -from [get_ports {eeprom_scl}] 50
set_min_delay -from [get_ports {eeprom_scl}] 0
set_max_delay -from [get_ports {eeprom_sda}] 50
set_min_delay -from [get_ports {eeprom_sda}] 0
Nurina
