15 years agoHow do I turn auto global clock signals off?
Hi again!
Does anyone know how to turn this off in Version 10? It's adding macrocells to my design that I just can't afford. This system message: Info: Promoted clock signal driven by pin "clk" to global clock signal Thanks!3 Replies
--- Quote Start --- Actually, that website doesn't help at all. The option it specifies isn't there... :( --- Quote End --- Hi, open the Assignment Editor. Double click into the tab "Assignment Name" , choose "Global signal". Go to the value tab and choose "off". In the "to" tab you have to specify your signal. Using "*" should switch the global feature off. That should solve your problem. Kind regards GPK - Altera_Forum
