AMess8
6 years agoHow do I recover my EthernetBlaster II?
I pressed the factory reset button and then tried to connect to the ethernetblaster with no success. I am unable to access the configure page via my browser. The user manual says that the default IPaddress is 192.168.0.50. My device is defaulting to 192.168.0.160. Typing this IP into the browser does not bring up anything.
- JohnT_Altera
I am glad to that you are able to resolved the issue which is cause by the network security.
- JohnT_Altera
May I know if you are connecting to the Ethernet Blaster II directly or using DHCP? If you are connecting it directly then have you configure the IP to 192.168.0.1?
- AMess8
Thank you for responding John. Fortunately I discovered the issue to be a problem with my company's network security settings.
