13 years ago
How do I get the address of the PHY port on an EP3C120 dev board?
I'm working with the Cyclone III dev board (EP3C120), where I can use the Triple Speed Ethernet MegaCore for a communication. But for this I need to have the address of the PHY port on the board. I've checked in the data-sheet but could not find it anywhere... Where can I get any information about it? Thanks.:)
    --- Quote Start ---
    I got this board (http://www.altera.com/products/devkits/altera/kit-cyc3-dsp.html) and on it is exactly the Marvell 88E1111 chip
    --- Quote End ---
    Page 13 of the schematic has the PHY, with
    CONFIG[0] = LED_RX = 010b => PHY address [2:0] = 010b
    CONFIG[1] = LED_LINK10 = 110b => PHY address [4:3] = 10b
    So PHY address [4:0] = 10010b = 12h
    The PHY is configured to use MDIO mode, so this is the address you need to use along with the MDIO bus protocol (rather than using I2C).
    Cheers,
    Dave
    Post a link to the board you have. Most of the Altera kits I have use a Marvell 88E1111 with a PHY address of 0, using MDIO mode for the communications interface.
    For a PHY address of zero, config[0] = GND, and config[1] = LED_LINK1000.
    If your board has this PHY, but a different connection, respond with the link and I'll look in the PHY data sheet to tell you what the address is.
    Cheers,
    Dave
    The phy address will be set by a few external resistors on the IC. These pins are used to bootstrap some parameters, like phy address, autoneg state, media mode, etc. that can be tied to a series of config pins. It's more than likely the sch (and board docs) will tell you the phy address.
