13 years agoHow do I get the address of the PHY port on an EP3C120 dev board?
Hello, I'm working with the Cyclone III dev board (EP3C120), where I can use the Triple Speed Ethernet MegaCore for a communication. But for this I need to have the address of the PHY port on ...
13 years agoPost a link to the board you have. Most of the Altera kits I have use a Marvell 88E1111 with a PHY address of 0, using MDIO mode for the communications interface.
For a PHY address of zero, config[0] = GND, and config[1] = LED_LINK1000. If your board has this PHY, but a different connection, respond with the link and I'll look in the PHY data sheet to tell you what the address is. Cheers, Dave
