14 years agoHow convert Hex file to SOF, POF or any format for use with USB Blaster
Hello in past I design aplication for FPGA, the programming is in system for a microporcessor, this take the information from memory flash and send to FPGA, this is OK, but I lost the design file and...
14 years agoHello
The programming in board is PPS, and this function is OK I start a revision of older design, and need verify with JTAG port, but I can´t verify with USB Blaster, I only have the hex file for Flash memory, for this reason I want convert hex file to sof or pof. In this moment work in the hex file for substitute the content in empty pof file But I apreciate if exist any other idea Thanks and best regards
