SusanB
6 years agoHow can you tell how much CFM (MAX 10 device family) your compressed .pof file takes up if the generated file size is not indicative of the compression ratio?
I saw another post that said you could use the raw binary to know how big your image really is, but that the POF is sized to the device. What if you are using a family that doesn't support generati...
ShafiqY_Intel
6 years agoHi SusanB,
To understand the Compress/Decompress algorithm, it is a low level explanation (confidential information). I can't explain to you since it is a confidential info.
The compression ratio for the configuration image should be at least 30% for the device to be able store two configuration images. However, the compression ratio is the design dependent (30% reduction size -- some people can fit into internal flash & some people can fit into the internal flash).
cheers
