17 years agohow can I use sdram
hello,everybody: I want to use off chip sdram as a data menmory. First I store some data in sdram. Second I want process these data in nios II processor using c language. But how ca...
17 years ago --- Quote Start --- I want to make sure that this solution you provided is pure Verilog (There is no NIOSII). Because I saw a SOPC builder. --- Quote End --- Do you wish to write owner sdram controller (in verilog)? --- Quote Start --- I only need a Verilog module that is able to write into the SDRAM without NIOS. --- Quote End --- NIOS is only part of SOPC facilities. I would recommended to read quartus. embedded peripherals (http://www.altera.com/literature/hb/nios2/n2cpu_nii5v3.pdf) --- Quote Start --- Please, if you can illustrate it a little bit for me, it will be very helpful for me. --- Quote End --- Look at attachment. It`s only piece of my project (verilog), summary: 1. exten device (camera. without file) -> fifo -> controller_sops (without verilog) -> sopc_sdram_0 -> sdram 2. sdram -> sopc_sdram_0 -> controller_sops (without file) -> uart note: in sopc_sdram_0 there are 2 no coupled part (1-write sdram, 2 - read sdram) of course, it`s only part exampl, but i think it would help you.
