17 years agohow can I use sdram
hello,everybody: I want to use off chip sdram as a data menmory. First I store some data in sdram. Second I want process these data in nios II processor using c language. But how ca...
17 years agoThanks for your quick reply.
I want to make sure that this solution you provided is pure Verilog (There is no NIOSII). Because I saw a SOPC builder. I only need a Verilog module that is able to write into the SDRAM without NIOS. Please, if you can illustrate it a little bit for me, it will be very helpful for me. Thanks
