17 years agohow can I use sdram
hello,everybody: I want to use off chip sdram as a data menmory. First I store some data in sdram. Second I want process these data in nios II processor using c language. But how ca...
17 years ago --- Quote Start --- I need help regarding the first phase you did which is writing into the SDRAM using Verilog. --- Quote End --- It`s one of the way to use sdram: 1. great in SOPC system with 1. sdram controller core (http://www.altera.com/literature/hb/nios2/n2cpu_nii5v3.pdf) and avalon master (look at AVM.ZIP) 2. connect your master in verilog ( with avalon (http://www.altera.com/literature/manual/mnl_avalon_spec.pdf?gsa_pos=1&wt.oss_r=1&wt.oss=mnl_avalon_spec)) to made system about avalon (http://www.altera.com/products/software/quartus-ii/subscription-edition/design-entry-synthesis/qts-des-ent-syn.html#sopc)
