15 years agoHow can i use CORDIC ?
Hello i am trying to use the cordic core { http://opencores.org/project,cordic } with no sucess. Say i have a complex number of 4 + 5i. I have inserted 1000 as the Xi input and 1001 as the Yi...
14 years agoYou can multiply a signed/unsigned with an integer with the numeric_std library. Be careful with multiplying fixed point vectors though, as you will need to shift the result back.
As for your 0 result, it is because with this assignment: --- Quote Start --- constant um_terco : signed (40 downto 0) := to_signed(integer(0.3333),41); --- Quote End --- 0.3333 is converted to the integer 0. You forgot to multiply 0.3333 by the scaling factor.
