SYiwe
7 years agoHow can I eliminate negative slack in RapidIO IP Core
Hi, In my design there's a 5G 4X Rapid IO IP Core. A single TX PLL is instantiated to drive tx_bonding_clock_ch0~3. I've tried to drive the sysclk signal with txclk(output from the RapidIO IP Cor...
Nathan_R_Intel
Contributor
7 years agoHie,
From your description alone, I cannot determine what is causing the timing error. Could you attach your design achieve (.qar), together with which Quartus version used for me to help you with this error.
Nathan
SYiwe
7 years agoThanks.
Can you give me an email address so I can send my design to you?
Regards.
