SYiwe
7 years agoHow can I eliminate negative slack in RapidIO IP Core
Hi, In my design there's a 5G 4X Rapid IO IP Core. A single TX PLL is instantiated to drive tx_bonding_clock_ch0~3. I've tried to drive the sysclk signal with txclk(output from the RapidIO IP Cor...
Nathan_R_Intel
Contributor
7 years agoHie,
From your description alone, I cannot determine what is causing the timing error. Could you attach your design achieve (.qar), together with which Quartus version used for me to help you with this error.
Nathan
- SYiwe7 years ago
Can you give me an email address so I can send my design to you?
Regards.
