FVanE1
6 years agoHow can I connect an IO-PLL output clock to a reference clock input of a transceiver?
I have a ref clock of 312.5 MHz as input at the FPGA, a transceiver which requires 322.265625 MHz and 5.15625 GHz as reference clock inputs. The 5.15625 GHz can I make with a fPLL or ATX-PLL and conn...
FVanE1
6 years agoDear Sree,
Thanks again. I was able to build your design. I will try to connect it at the same way in my own design.
Frank
