FVanE1
6 years agoHow can I connect an IO-PLL output clock to a reference clock input of a transceiver?
I have a ref clock of 312.5 MHz as input at the FPGA, a transceiver which requires 322.265625 MHz and 5.15625 GHz as reference clock inputs. The 5.15625 GHz can I make with a fPLL or ATX-PLL and conn...
SreekumarR_G_Intel
6 years agoHello Frank ,
Thank you for the input ,
I could able to do fitter compliation passed with two method as below
i) IOPLL output connected to FPLL aand FPLL generate the required datarate clock. (More jitter )
ii) FPLL output connected to ATX PLL and ATX PLL generate the required datarate clock. (Recommeded Method)
Here is attached example design for your reference and let me know if you have any question/concern
Note : This is not complete design for 10G KR base PHY ; just to make sure i can route the XCVR PLL use Fabric PLL.
Hope Helps
Thank you ,
Sree
FVanE1
6 years agoDear Sree,
First of all, thank you for your support. However, I am not able to open the archived project file. I tried it with Quartus 19.2 Pro, could that be the problem (according to the filename it looks like you used 19.3)?
The corresponding logging:
******* Archived project restoration attempt on Tue Jan 21 13:48:30 2020
Source archive file: /home/frank/proj/pit17018/tmp/intel support/a10_xcvr_fpll_19_3_0_222.qar
Quartus Prime failed to read the archive or extract some files into
/home/frank/proj/pit17018/tmp/intel support/a10_xcvr_fpll_19_3_0_222_restored/.
======= Files failed to restore before extraction terminated: ======
Met vriendelijke groeten / With kind regards,
*Frank van Eijkelenburg* Lead Designer
*T* +31(0)182594000 | *E* [email protected]
<http://www.google.com/url?q=http%3A%2F%2Flinkedin.nl%2F%253C%253Cvoornaamachternaam%253E%253E&sa=D&sntz=1&usg=AFrqEzdYyF21CXz0c9GlCBfxLRkl-NCpRw>
*A* Burgemeester Jamessingel 1, P.O. Box 2013, 2800 BD Gouda, The
Netherlands | *W* technolution.com
This e-mail is intended exclusively for the addressee(s), and may not be
passed on to, or made available for use by any person other than the
addressee(s). Technolution B.V. rules out any and every liability resulting
from any electronic transmission.
