FVanE1
6 years agoHow can I connect an IO-PLL output clock to a reference clock input of a transceiver?
I have a ref clock of 312.5 MHz as input at the FPGA, a transceiver which requires 322.265625 MHz and 5.15625 GHz as reference clock inputs. The 5.15625 GHz can I make with a fPLL or ATX-PLL and conn...
SreekumarR_G_Intel
6 years agoWhich IP and device part number you are using ? So I can try it out and create one example design and send to you.
Thank you ,
Sree
- FVanE16 years ago
Dear Sree,
I am using the Arria 10 (10AS027E4F29E3SG) as device part and the IP I am using is the "1G/10GbE and 10GBASE-KR PHY Intel Arria 10" (where the 1 GbE interface is disabled). I want to use it in combination with the "Low Latency Ethernet 10G MAC". I also use the "Transceiver PHY Reset Controller".
Frank
