9 years agohold time violation using MAX V
Hi, I saw some hold time violation when I trying to run the STA. I believe the problem is because the source and destination FFs of this path are on different clock domains, and the tool thin...
9 years ago --- Quote Start --- Hi ak6dn, Thanks so much for your help! I just use a FF as a divider, i'm not using the pll to create the output clock, please see below verilog code. always @(posedge clk or negedge reset) begin if (!reset) two_clkout <= 0; else two_clkout <= ~two_clkout; end and sdc comment: create_clock -name {clk} -period 50.000 -waveform { 0.000 25.000 } [get_ports {clk}] do I need to put the create_generated_clock for the output clock into the sdc file,even though I just use a FF divider? Thanks a lot! --- Quote End --- Yes, unless Quartus detects that FF output as a clock (from your description of the problem however it appears not to). I would use something like: create_generated_clock -name two_clkout -multiply_by 2 -source [get_ports {clk}] [get_registers {two_clkout}] and then validate in your DESIGN.sta.rpt file in the CLOCKs table that it appears as it is supposed to as a clock.
