9 years agohold time violation using MAX V
Hi, I saw some hold time violation when I trying to run the STA. I believe the problem is because the source and destination FFs of this path are on different clock domains, and the tool thin...
9 years ago --- Quote Start --- So output clock is input clock divided by two. Do you use a PLL to generate the output clock, or just a FF as a divider? Do you use sdc commands create_clock and / or create_generated_clock, or derive_pll_clocks (if using pll). Can you show the sdc commands you use? --- Quote End --- Hi ak6dn, Thanks so much for your help! I just use a FF as a divider, i'm not using the pll to create the output clock, please see below verilog code. always @(posedge clk or negedge reset) begin if (!reset) two_clkout <= 0; else two_clkout <= ~two_clkout; end and sdc comment: create_clock -name {clk} -period 50.000 -waveform { 0.000 25.000 } [get_ports {clk}] do I need to put the create_generated_clock for the output clock into the sdc file,even though I just use a FF divider? Thanks a lot!
