9 years agohold time violation using MAX V
Hi, I saw some hold time violation when I trying to run the STA. I believe the problem is because the source and destination FFs of this path are on different clock domains, and the tool thin...
9 years ago --- Quote Start --- Hi, the output clock is half frequency of input clock. output clock(100ns), input clock(50ns). when I run RTL simulation, everything looks good. however, when I trying to run gate level simulation, the output clock always delay one input clock period . I have set multicycle exception for these two clock, but still see the shift. set_multicycle_path 1 -setup -start -from CLK -to CLK2 set_multicycle_path 0 -hold -start -from CLK -to CLK2 I not sure what the problem is. Thanks! --- Quote End --- So output clock is input clock divided by two. Do you use a PLL to generate the output clock, or just a FF as a divider? Do you use sdc commands create_clock and / or create_generated_clock, or derive_pll_clocks (if using pll). Can you show the sdc commands you use?
