cosx
5 years agoHLS compiled qsys modification and regeneration problem
Hi everone,
I came across a question about modifying HLS generated qsys and regeneration of the modified system.
My quartus SDK compiler is 15.1.
I compiled a .cl file using command "aoc -s -v ...
cosx
5 years agoHi everyone,
A new update here:
when I use aoc -v to compile the project, some strange messages occur:
com.altera.hdlwriter.EntityWritingException: Connection is not connected float_add:avm_local_bb1_ld__inst0 -> ?
at com.altera.hdlwriter.internal.OldEntityWriterInternal.addConnection(OldEntityWriterInternal.java:431)
at com.altera.hdlwriter.internal.OldEntityWriterInternal.writeHDLInternal(OldEntityWriterInternal.java:122)
at com.altera.hdlwriter.internal.EntityWriter.writeHDL(EntityWriter.java:40)
at com.altera.sopc.generator.EnsembleGenerationFileSet2.generate(EnsembleGenerationFileSet2.java:61)
at com.altera.sopc.generator.FileSet2.generate(FileSet2.java:150)
at com.altera.sopc.generator.Sellafield.generate(Sellafield.java:366)
at com.altera.sopcmodel.sbtools.sbgenerate.SbGenerate.performGeneration(SbGenerate.java:518)
at com.altera.sopcmodel.sbtools.sbgenerate.SbGenerate.act(SbGenerate.java:464)
at com.altera.utilities.AltCmdLineToolBase.runTheTool(AltCmdLineToolBase.java:718)
at com.altera.sopcmodel.sbtools.sbgenerate.SbGenerate.main(SbGenerate.java:965)
May I ask has anyone come across this before?
It seems that my defined IP has problems, but don't know why it has problems..
Thank you again!
Mingqiang
OliverTheEngineer
1 year agoHello Cosx,
I'm having exactly the same problem, 4 years later... I have not seen any other occurrences of this error, do you remember if and how you solved it?
Thank you,
Oliver
