14 years agoHigh-Z in the Cyclone family
In my design of Cyclone IV, when I define an output in High-Z state and at the same time I pull this output to VCC/GND with a small resistor of ,say, 100ohm. Will this action somehow damage the output stage of the Cyclone? How high is the High-Z state in the Cyclone family? Thank you, Boris.2 Replies
Thank you all.
will not be damaged, even if you connect the high-z pin directly to power(io) or ground.
high-z is often used as an input state for a bidir pins.
