14 years agoHigh-Z in the Cyclone family
Hello, In my design of Cyclone IV, when I define an output in High-Z state and at the same time I pull this output to VCC/GND with a small resistor of ,say, 100ohm. Will this action somehow d...
14 years agowill not be damaged, even if you connect the high-z pin directly to power(io) or ground.
high-z is often used as an input state for a bidir pins.
