12 years agoHigh speed 16b paralell bus to DSP
Hello, i am quite new with FPGA, and need ideas how to solve my problem. I have 128 points CCD, and i control detector as well as ADC from FPGA. FPGA connects to DSP processor by standard SRAM ...
12 years ago --- Quote Start --- Have you considered using the SHARC PDAP port? --- Quote End --- Well, it looks like PDAP is not that slow after all, it is capable 1Gbps, at 18bits, but again, not that easy, it only support SLAVE configuration, i have no idea how to make it work, since i need to get data and know which ADC readout which CCD pixel i will try to do more research on PDAP
