10 years agoHigh bandwidth data transfer between hps and fpga
Hi, I need to High bandwidth data transfer between hps and fpga. Which bridge should i use? I used light weight bridge but the speed of transfer data was up to 3MHz. Best Regards
9 years ago --- Quote Start --- Thanks for reminding. It seems like my flow currently, but I wanna give it a try. :confused: How do you configure the flow from sdram to TCP/IP? Where can I configure the IP address, port for socket? Could you share some ideas to implement it? --- Quote End --- I'm not a software guy, so I cannot give any detailed advice on this. But I guess you are using Linux in your system. The ethernet settings can be configured using /etc/network/interfaces.
